skeleton directory for addon and sub domains
Whenever a hosting customer creates a subdomain or addon domain, a plethora of errors appear in the Apache error logs because favicon.ico, robots.txt and 404.shtml do not exist by default. This causes an unnnecessarily large error log file even with custom logging.
Since hosting providers solve this issue for primary domains by using skeleton directories, it is proposed that we use that same skeleton directory for addon and sub domains. This lets hosting providers just solve these problems or go a step further with a "Website coming soon, here's how you upload" page and other brandings they build.
There is no need to have a separate skeleton directory for this, so let's use the same skeleton directory used for that account (the skeleton directory of the reseller/root user that owns that account).
The strong reasoning used for justifying skeleton directories in the first place is being used here for justiifying sekeleton directories for addon domains and subdomains.
Original thread: http://forums.cpanel.net/f145/case-48382-skeleton-directory-addon-sub-domains-146569.html
The sooner the better, on busy servers it generate loads of unnecessary errors.
Yes, that's a must!
Please cPanel, do consider and implement this.
Any chance we could get it any time soon? When?
Thanks,
Yes, that's a must!
Thanks,
We are starting development on a feature we've provisionally called 'Starter Sites' which provides the means for end-users to create, well, starter sites from site templates. If these Site Templates include template favicon.ico, robots.txt and 404.shtml files... in addition to template index.html files and the related IMG, CSS or JS assets...would that resolve the problem for you?
Any update on this? Just got started using cPanel and this is something we'd really like to see. Seems like it would be an easy fix.
This has also caused issues for us with .htaccess. When a user already has an install of software in public_html that has mod-rewrite rules, depending on the ruleset (I've noticed not all software does this but a popular package with our client base does) subfolders will throw a 500 error if they don't have their own .htaccess file with RewriteEngine On.
I simply want my custom skel files from /root/cpanel3-skel (I have a set including custom index.html , blank robots.txt , generic favicons, and my custom 400.shtml thru 500.shtml files) to be automatically populated into any Addon Domains that user's create, just like it does for the public_html when I create a new hosting account. Will this ever become possible cPanel?
