Second Hard Drive
Open Discussion
Hello,
Many new servers are coming with second hard drives, with out through the SSH manual update to find and mount, would be great if WHM had this already installed. When adding accounts to the server a menu drop down box to pick the drive.
Cheers
Michael
Please keep discussion in this feature restricted to "I would like a GUI in WHM for mounting hard drives so I don't have to use SSH to do this." Discussion and requests on how that additional drive should be used needs put into a different feature request. Please keep in mind that cPanel & WHM will already function out of the box with multiple mount points for account creation.
We used to have a feature in WHM for formatting and mounting hard drives. We removed the feature as it caused many problems for users. A question I have related to that, how should the following devices be represented in your proposed user interface:
I think this needs to be expanded to where you can set /home max
defaults and when that /home has reached a max count, it starts a new
/homeX (x being a number) on another assigned drive. This way you can
span drives and this would fit into cPanels backup.
Adding a second drive if mounted should be apart of the WHM script, and should be easy to use.......Not going into SSH and making all the changes.......Plus Cpanel gave me a third party web site to complete the SSH update......
Makes me think
Michael
Makes me think
Michael
Need this feature to easily add additional mounted hard drives as usable space in cpanel.
"We used to have it but don't anymore cause we're not savvy enough to make it work properly" IS NOT AN ACCEPTABLE ANSWER.
