mod_antiloris and mod_security2 and mod_ruid2 +CSF embedded and better controlled directly into cpanel WHMC?
Roberto Santin shared this idea 12 years ago
Open Discussion
Hi,
I'm focusing with the security layer of cpanel and I did found a perfect solution if you will implement mod_antiloris (for DOS attacks) and ModSecurity with Atomic ModSecurity WHM plugin ConfigServer ModSecurity Control (CMC) and CSF.
with these 4 tools a web hoster can keep away 99% of automated scripts that scans for server and website vulnerabilities and bad behaviour as:
- xxs attacks
- malware
- spam
- sql injection in general
- rootkits
- user agents (bad bots)
- brute force
- DOS in general (not DDOS at the moment)
It will be nice if all these modules could be integrated in cpanel (as optional or free) ...
These 4 applications will do a great job all together in order to control malicious behavior from autmated scripts, in fact as for today many hackers le these scripts run and as soon as a vulnerability is found the hacker goes check and try these kind of attacks and maybe cracks into a system (if you're lucky they will gain a web space access, but if you're unlucky they could gain server access).
Thanks a lot if you go to this direction...
Replies (1)
I think security is utmost important
