Keep ace editor settings changes
Open Discussion
As a cPanel user I would like the Ace Editor to retain my settings between uses so that I don't have to manually apply those settings every time I use them. For example, I have to uncheck 'Show Page Margin' each time I edit a file.
Definitely. What good are settings if you have to re-set them every single time. Even if you just reload the page...gone. at this point, the settings panel is pointless without the ability to save the settings.
