As we have now letsencrypt free certs for every user , they also need to redirect all traffick to https to take it effect. Also http2 works only with ssl. Currently it cannot be done in cpanel. Most of customers don´t have knowledge to edit .htaccess file and they will not use benefits of new techologys. In my experinece now only 15% of customers have done manual redirect by editing .htacess file. Please bring tht option to cpanel ASAP.
Allow users to require http to https redirection on their site and/or addon domains
Completed
There should be an option somewhere in the cPanel UI that will enable automatic redirection/rewriting from http to https.
It should be able to be enabled/disabled for the main site, as well as any addon or sub domains.
Currently you can do this via .htaccess or by modifying the vhosts, but a nice UI option would make it a lot simpler.
This is currently underway and will be in the next version or two. Check out the preview...
Let us know if you have feedback!
