Exim remove Sender IP from Remote SMTP
Milutin Kubik shared this idea 16 months ago
Needs Review
Hello,
It would be great to allow custom modifications of exim.conf. We need to add "headers_remove = received" to remote_smtp and dkim_remote_smtp but we are not able to do so.
Reason why to add headers_remove = received is that if you are using older version of Outlook it will add your ISP IP to Received header which will leak your IP (not good for privacy) and it might get marked as a SPAM email if your IPS got emails blacklisted by Barracuda for example.
Never version of Outlook send your email via Proxy and it will hide your IP with Microsoft IP. Same for iOS Mail / macOS Mail and so on.
When you are using WebMail you are also not leaking your IP, there is server IP, so this do not violate anything there still will be IP of MTA.
Replies (1)
Hey there! Is this not something you can do with the WHM >> Exim Configuration Editor under the "Advanced" tab?
Hey, nope this is not possible right now.
