using 7zip for backung up data instead of tar.gz files?
JedClampett shared this idea 11 years ago
Completed
I run Centos 5.9 at home on my Linux server, and use Windows at work. As
CPanel
backups are currently done as tar.gz files, instead for the backup
file format, could we have the backups done using 7-Zip, which is a file
archiver with a high compression ratio please?
/http://www.7-zip.org/
  1. You can use 7-Zip on any computer, including a computer in a commercial organization. You don't need to register or pay for 7-Zip.
    The main features of 7-Zip
    igh compression ratio in 7z format with LZMA and LZMA2 compression
    Supported formats:
    Packing / unpacking: 7z, XZ, BZIP2, GZIP, TAR, ZIP and WIM
    Unpacking only: ARJ, CAB, CHM, CPIO, CramFS, DEB, DMG, FAT, HFS, ISO, LZH, LZMA, MBR, MSI, NSIS, NTFS, RAR, RPM, SquashFS, UDF, VHD, WIM, XAR and Z.
    For ZIP and GZIP formats, 7-Zip provides a compression ratio that is 2-10 % better than the ratio provided by PKZip and WinZip
    Strong AES-256 encryption in 7z and ZIP formats
    Self-extracting capability for 7z format
    Integration with Windows Shell
    Powerful File Manager
    Powerful command line version
    Plugin for FAR Manager
    Localizations for 79 languages
    7-Zip works in Windows 7 / Vista / XP / 2008 / 2003 / 2000 / NT / ME / 98. There is a port of the command line version to Linux/Unix.
    On 7-Zip's Source Forge Page you can find a forum, bug reports, and feature request systems.
For people that want to unpack their downloaded backup files on a
Windows or Linux machine this would solve the problem. Also I've heard
and experienced that tar does not always get the backups done correctly.
