Remote domain verification
As a webhosting provider, I would like to add a 3rd option for users adding parked/addon domains, offering DNS Verification or a specific verification file added to the process of adding a remote domain to any cPanel end-user’s account so that the process will be more convenient and secure.
Currently cPanel has two options for allowing end-users to add domains as parked/addon domains that direct to remote systems, being:
On (most convenient for users, but also a security hole)
Off (incredibly inconvenient for users as it's impossible to self-add domains in advance of directing them to their new home).
Could a third option be added here (or simply change the behaviour of Off) to allow user verification of remote domains?
So when a user attempts to add a remote domain, instead of the system simply telling them no can do, a verification is triggered that requires, for example, a DNS entry being added to the domain's existing nameservers or a specific verification file being added to their existing hosting (much the same as pretty much any domain-ownership-verification system).
Once this verification has been completed, the domain is then added to their account for use.
This needs to be implemented because it is just a common sense feature, there is no downside and only positives for both admins and end users.
This is a very good solution, that is desperately needed.
It might also be good to have an option as root (via WHM or CLI) to specify a domain that can be added in spite of it being a remote domain. This would allow a quick exception to be added upon request for a specific domain to be added on that particular server.
Some registrars such as registro.br prevents the user from changing the nameserver if the new server refuses a nslookup query. If "Allow Remote Domains" is set to Off in the case, the user can't add the domain and also can't change the domain's nameservers.
