Global Email Filters - Body.Contains.String Bug
As a cPanel User, I would like to be able to create custom global filters that will work for both HTML and plain text emails so that I can automatically filter out messages in foreign languages to eliminate spam.
For example: change the If condition in filtering FROM
If varMsgBody.Contains(“?”) = True ThenTO
If varMsgBody.Contains(“?”) = True Or varMsgBody.Contains(Uri.EscapeUriString(“?”)) = True Then
I Created 2 global filters: Russian & Chinese
In each filter, I enter the most used chars in each language and set if Body contains any of them, fail with a message!
For Russian, I enter both lower & upper case in separate fields.
But they will NOT work in HTML emails!
You can fill the UTF-8 email body with all of the blocked characters but it's not filtered and received!
cPanel 78.0.21. Site owner, no root access.
Your filter system is simply like this:
varMsgBody is the variable holding the whole email message body
? is the Russian character I entered in the filter list (along with some others)
If varMsgBody.Contains("?") = True Then
'Fail with message
End If
While you should also:
If varMsgBody.Contains("?") = True Or varMsgBody.Contains(Uri.EscapeUriString("?")) = True Then
'Fail with message
End If
Because in the inner message source ? is converted to =D0=99 so you should check both for the entered character and it's HTML encoded form so your code logic works in all conditions with all characters.
*** Please note that Uri.EscapeUriString("?") in .NET converts ? to =D0=99Unfortunately I don't know the equivalent in Perl
Full thread ( from Forum to Support, from Support to Features, next location?! :D )
https://forums.cpanel.net/threads/global-email-filters-body-bug.651997/
