fix security advisor when using imunify
dzamanakos shared this idea 2 years ago
Needs Review
As a server administrator I would like cPanel's Security Advisor to make correct recommendations when imunify is used.
At this point, security advisor reports that i should enable cphulk, a service that is replaced by imunify firewall. There should be a check to remove this recommendation if imunify is installed.
Second false report is that " The MySQL service is currently configured to listen on all interfaces: (bind-address=*)" and it proposes to "Configure bind-address=127.0.0.1 in /etc/my.cnf or use the server’s firewall to restrict access to TCP port “3306”
I use the bind address to * by purpose and use firewall rules to manage the connections.
Cpanel should check if there is a port 3306 rule in the firewall (doing anything) and remove this recommendation as well.
best,
