Add help block for multiple recipients to "Forward to Email Address" feature
Open Discussion
As a cPanel user, I would like to see a tooltip added in the forwarders interface informing users that they can use a comma separator to set multiple recipients to help make it more clear how this can be utilized.
As I searched for a few minutes before I found that solution, I suggest to add help block under the "Forward to Email Address" field to inform that we can set multiple recipents by using a comma.
Here is an example :
Snippet :
<div class="col-xs-offset-1 col-xs-11 col-sm-6 col-md-6 col-lg-6"> <span id="fwdemail_clickmask"> <input name="fwdemail" id="fwdemail" type="text" class="form-control"> </span> <div class="row"> <div class="col-md-12"> <span class="help-block"> To set multpiple recipients, use comma separated email adresses. </span> </div> </div> </div>
