/scripts/easyapache should exit with proper code when build failed
deepunix shared this idea 11 years ago
Open Discussion
/scripts/easyapache always exits with 0 exit status irrelevant of whether the buildout was successful or not.
It should set proper exit code because our automation tools can't distinguish between a failed build and a successful one.
Steps to reproduce:
1. Run /scripts/easyapache with profile that has either wrong settings or wrong extensions selected.
2. echo $? after it. You'll see it's always "0".
For ex., here's an example of failed build. Note the ENDOFBUILD line that prints $?.
checking for Firebird support for PDO... no
checking for MySQL support for PDO... yes, shared
checking for PDO includes... checking for PDO includes... /home/cpeasyapache/src/php-5.4.17/ext
checking Oracle OCI support for PDO... no
checking for ODBC v3 support for PDO... no
checking for PostgreSQL support for PDO... no
checking for sqlite 3 support for PDO... yes
checking for PDO includes... (cached) /home/cpeasyapache/src/php-5.4.17/ext
configure: error:
You've configured extension pdo_sqlite, which depends on extension sqlite3,
but you've either not enabled sqlite3, or have disabled it.
!! './configure --disable-fileinfo --enable-bcmath --enable-calendar --enable-ftp --enable-gd-native-ttf --enable-libxml --enable-mbstring --enable-soap --enable-zip --prefix=/usr/local --with-config-file-path=/etc --with-config-file-scan-dir=/etc/php.d --with-curl=/opt/curlssl/ --with-freetype-dir=/usr --with-gd --with-imap=/opt/php_with_imap_client/ --with-imap-ssl=/usr --with-jpeg-dir=/usr --with-kerberos --with-libdir=lib64 --with-libexpat-dir=/usr --with-libxml-dir=/opt/xml2 --with-libxml-dir=/opt/xml2/ --with-mcrypt=/opt/libmcrypt/ --with-mysql=/usr --with-mysql-sock=/var/lib/mysql/mysql.sock --with-mysqli=/usr/bin/mysql_config --with-mysqli=mysqlnd --with-openssl=/usr --with-openssl-dir=/usr --with-pcre-regex=/opt/pcre --with-pdo-mysql=shared --with-pic --with-png-dir=/usr --with-xmlrpc --with-xpm-dir=/usr --with-zlib --with-zlib-dir=/usr --without-sqlite3' failed with exit code '256' !!
!! Restoring original working apache !!
!! Executing '/scripts/initsslhttpd' !!
!! Restarting 'httpd' ... !!
!! 'httpd' restart complete. !!
Building global cache for cpanel...Done
!! Executing '/scripts/initfpsuexec' !!
!! Executing '/scripts/update_apachectl' !!
!! Executing '/scripts/enablefileprotect' !!
Compiling report...
Sending report. As some of the attached files may be quite large, this could take a few minutes. Thanks for your patience.
!! If you want to create a support ticket with cPanel regarding this please reference 'BuildAP Report Id': '11271877' !!
Report processed.
!! Feel free to submit a support ticket at https://tickets.cpanel.net/submit/index.cgi?reqtype=tickets !!
!! Verbose logfile is at '/usr/local/cpanel/logs/easy/apache/build.1374159892' !!
ENDOFBUILD: 0
Thanks.
